Blackhole crackling
Home Forums Products Plug-Ins Blackhole crackling
    • #114982
      Bagmand
        Hi there
        I resently bought the Blackhole reverb plug- in and i was very exited to try it out. I opend my DAW wich is FL20 in this case, loaded the plug-in and then my ears nearly fell of!! It has a very bad “crackling” noise when i play any sound. I have never come across this problem before, and i cant seem to figure out whats causing it. When i turn the mix knob all the way up, the crackling goes away. So I guess it is is only affecting the dry signal and not the wet.
        Any one else with this problem, or with a solution?
        Regards Henrik
      • #150252
          Hello Henrik. Please try downloading the latest installer for Blackhole. We very recently came out with an update that fixes this issue.
          https://www.eventideaudio.com/support/product/721/installers
        • #150253
          Bagmand
            This has solved my problem.
            Thank you!
