Blackhole Immersive not working in 9.1.6
Home Forums Products Plug-Ins Blackhole Immersive not working in 9.1.6
Viewing 9 reply threads
    • #194059
      MikeA57
        All Software is currently up to date as of this post.
        Mac Studio M1.
        1) Nuendo 14 using internal renderer works fine with 9.1.6 configuration.
        2) Nuendo 14 using External Dolby Renderer V5.3, 9.1.6 configuration does not work. Also tried 9.1.6 ITU.
      • #194193
          Hello, can you please be more specific about the issue you are having with the external renderer?
          Is audio not passing in the correct channels, or is it something else?
        • #194195
          MikeA57
            Hi, thanks for getting back to me, audio appears on the meters but does not pass through the plugin, I am in the process of recalibrating my system/room so I will try to give a more detailed description one finished.
            Happy New Year to you. MikeA.
          • #194921
            MikeA57
              Blackhole working ok on my current project.
              Micro immersive not working, reverts Stereo with a yellow/orange indicator?
            • #194923
              tlongabaugh
                Hey, sorry to hear MPI is now giving you trouble. If you could email support@eventideaudio.com with the following, we can help you troubleshoot there:
                • OS version
                • Plugin version
                • iLok account name
                • A screenshot or screen recording of the issue
              • #194924
                MikeA57
                  Hi, thanks for the reply, this morning I have reinstalled both BH Immersive and MP Immersive, BH appears to be working following some limited testing. MP is working but shows an Orange flag with 9.1.6L – see attached screen shot.
                  BH and MP – latest version from website as of last night.
                  OS version Sequola 15.6.1
                • #194930
                  tlongabaugh
                    Thanks, and to clarify MPI is only misbehaving when using the external Dolby Renderer?
                    If you could email support@eventideaudio.com with a session exhibiting the issue, that’d be very helpful.
                  • #194931
                    MikeA57
                      Good morning, I have just set up a simple Dolby session using Nuendo 14 and internal renderer. Same outcome (MPI showing orange 9.1.6Las per the images I sent for the external renderer V5.
                      Used Tahoe 26.2 and MacBook Pro for this test, Mac Studio for the previous one.
                      I can set same test up on the Studio if you require?
                    • #194938
                      tlongabaugh
                        Unfortunately we cannot reproduce the issue here. MPI loads and passes audio as expected on a 9.1.6 channel in Nuendo 14.
                        We can assist further if you send the following to support@eventideaudio.com. We can’t provide more support without the following:
                        • An example session exhibiting the issue
                        • A screen recording of the issue
                        • The plugin support information (right-click the Eventide logo in MPI and select “Copy Support Information to Clipboard”, and then include it in your email)
                      • #194940
                        MikeA57
                          Thanks for the information, I will discontinue trying to used the plugin with 9.1.6 configuration.
                          • #194978
                            tlongabaugh
                              Ok – for what it’s worth, we have every reason to believe we can resolve your issue, we just need the above requested information in order to troubleshoot further.
