Blackhole Pedal problem
Home Forums Products Stompboxes Blackhole Pedal problem
Viewing 3 reply threads
    • #193082
      Vehement
        Hello
        My blackhole pedal not work.
        When power up the top two present led light on then a sound like relay diconnect the bottom two present led light on. Then do any bottom or knob not work.
        What problem is it?
      • #193096
          It sounds like the pedal may be in Update Mode.
          Please download the H90 Control application here: https://www.eventideaudio.com/software/h90-control/
          Then connect your Blackhole to your computer via USB and select “dot9 Update Mode” from the app (see screenshot below).
          Let me know whats happens.
        • #194048
          Vehement
            It’s not work show no dot9 found in update mode
            Also if I choose add device it show a unknow divece in it and timeout with ID(0X71)
            The Blackhole show it is a USB Composite Device in my PC.
          • #194051
            Vehement
              By the way in that mode have some clue.
              When the power up the top 2 preset LED will light then the middle LED then the bottom 2 LED light.
              And active button and freeze button light. If push the active botton the active LED will close.
              For detail please check the attached video
