BPM/tempo not changing on Pitchfactor – with Tempo “On”
Home › Forums › Products › Stompboxes › BPM/tempo not changing on Pitchfactor – with Tempo “On”
Viewing 0 reply threads
    • #113995
      beedoola
        I recently bought a Pitchfactor used. I’ve owend two in the past and missed having one.
        I’m having an issue that I can’t remedy. I like having the Tempo “On” – by pushing the Mode Select button – because I like the delay time ratios: the 1/16, etc.
        The issue is that when I turn the Tempo On and them use the Tap switch, the tempo doesn’t change. When the Tempo mode is “Off” the BPM will change.
        What is the issue here? I have tried in the Global settings turning the Tempo On and OFF and that doesn’t help.
