BUG-81 WORKAROUND
Viewing 0 reply threads
    • #115659
      camn
      I wouldn’t keep this this way.
      The OFF setting is identical to the ZERO setting, is it not?
      I would just tuck OFF in between the ZEROS.. so any rounding error is not so dramatic.
      The problem is that OFF and -100 are so sonically distant. Just dont put them next to each other if you cant fix the jitter 🙂
      Why? Workarounds aside.. nothing is more annoying than saving a preset and then it is way different when you call it up.
