Can a stompbox foot switch be assigned as a hot switch?
Home Forums Products Stompboxes Can a stompbox foot switch be assigned as a hot switch?
    • #108686
      brien brannigan
        I'm using midi for program change & would like to use one foot switch for bypass & the other as a hot switch in that preset. Is that possible?
      • #123384
        achaput
          I didn't completely understand your question.Which stompbox are you using? Only SPACE has a Hotswitch.
          Do you mean you want to use the Eventide's onboard footswitches for Bypass and Hotswitch? On Space you can already do this in PLAY Mode.
          Or do you mean that you want to operate Bypass and Hotswitch over MIDI?
