Can’t play over loop Ultratap
Home Forums Products Stompboxes Can’t play over loop Ultratap
Viewing 4 reply threads
    • #168663
      zochar
        According to the instruction vid, I should be able to play over a loop without overdubbing when I bypass the pedal. My loop just stops when I disengage the active knob. Am I doing something wrong? Regards
      • #168664
        joecozzi
          Do you have your Bypass mode set to Relay?
        • #168665
          zochar
            Sorry, I’m new to this kind of pedal. I suppose I can set it to relay via usb? There was nu usb cable with my pedal, so I just ordered one.
          • #168666
            joecozzi
              Try setting your pedal to DSP Bypass. To access these Global Settings, apply power while holding ACTIVE Footswitch and triangle button on the top right. Once the lights are blinking, press the Active LED button (above the active footswitch) and make sure the third button on the preset ladder is lit for “DSP+FX.” Power cycle the pedal. Now try it.
            • #168668
              zochar
                Yes, that worked. Thanks a lot!
