Change Key of H9 Pitchshift via Midi
Home Forums Products Stompboxes Change Key of H9 Pitchshift via Midi
    • #177282
      dmbpettit
        Many of the pitch shift algorithms on the H9 require the key to be entered to assist with tracking. I know the key can controlled via a hotkey and the center wheel but can it be controlled via midi? It would be awesome if each key could be assigned to a control change but I don’t know if that’s possible
      • #177283
          Here’s how I do it for the Diatonic & QuadraVox algorithms.
          https://www.eventideaudio.com/forums/topic/pitchfactor-key-toggling-over-midi/#post-123733
          I built this chart for use with any kind of MIDI controller (and originally, a PitchFactor), but the FCB-1010  is particularly geared for this in a live application.
          It can send two CCs at once, for KEY + SCALE changes with one switch.  10 switches per Bank provide easy access to a lot of combinations.
          Notice there is a small range of CC values for any given KEY or SCALE.  Select your CC message, and any one of the individual CC values in each range will work.
        • #177293
          dmbpettit
            Thank you brock for the insight. I discovered that for the H9, the CC number is 28 and then your value chart for the CC Value is correct.
