Home › Forums › Products › Stompboxes › Confused about routing, please help?
- This topic has 4 replies, 2 voices, and was last updated 3 years, 1 month ago by
vitamin.
January 26, 2023 at 12:41 am #168677
I have the stereo outputs of two synthesizers running into H90 inputs 1/2 and 3/4. (Two stereo ins.) I want them to get inserted in the signal path at the places where inserts 1 and 2 are represented on the on-screen diagram, however that’s not what happens.
For example when I set both inserts at the beginning of the signal path, only one of the two stereo signals gets inserted (the 3/4 one).
I also tried turning to Stereo Insert mode, but then only inputs 3/4 get fed into the signal path even though it shows 1-2 on the screen. This seems like a bug, but the manual seems to indicate this is an intended behavior? Why does it not show 3/4 if it’s actually inputs 1/2 that are being inserted to the signal path at that spot?
What am I doing wrong? Is the problem that the H90 is incapable of summing both stereo inputs and feeding them in at the same spot?
Other than running Dual Mode is there no way to use two stereo inputs simultaneously and change how they are routed into the effects?
January 26, 2023 at 1:20 am #168678
This is a diagram showing what I am expecting and wanting to happen in the cases where I have inserts 1 and 2 assigned to the signal path in the initial spot or in a staggered setup:
In the top example Insert 1’s signal (the stereo input from 1/2) feeds into both effects (A then B), while Insert 2’s signal (the stereo input from 3/4) only feeds into the second effect (B).
In the bottom example both Insert 1 and 2 are fed in at the beginning, so they should be summed together then passed into A, then B.
However that is not what actually happens when I try this. In both examples, Input 1/2 plays with NO effects applied to it. Effects only get applied to Input 3/4 for some reason.
Can someone help me understand what I’m missing, or is this a bug? Thanks.
January 26, 2023 at 1:48 am #168680
This whole diagram is flawed from the get go because you are assuming I/O 1&2 correspond to Insert 1 and I/O 3&4 correspond to Insert 2. Inserts are loops for outboard effects. When in Insert Routing Mode, I/O 1&2 is the main H90 signal flow, not a loop.
January 26, 2023 at 1:44 am #168679
I want them to get inserted in the signal path at the places where inserts 1 and 2 are represented on the on-screen diagram, however that’s not what happens. For example when I set both inserts at the beginning of the signal path, only one of the two stereo signals gets inserted (the 3/4 one).
Insert 1 and Insert 2 are simply names for loops. They do not correspond to channel numbers. As per the Quick Reference guide and the user’s manual, Insert 1 and 2 are each mono loops that are connected to I/O 3 for Insert 1 and I/O 4 for Insert 2.
As stated above, Insert 1&2 is simply a name that indicates mono insert loops 1 and 2 are paired together to create a stereo loop. But the connections are still I/O 3&4 on the actual pedal.
Eventide never intentionally set out to make the H90 act like a mixer for both sets of stereo paths, but maybe through experimentation you can make adjustments to the Stereo Insert Mix levels to make it behave in such a way. If you are using Insert Routing Mode, try connecting one synth to I/O 1&2 and the other synth to I/O 3&4. Create a Stereo Insert which will show up on the display as Insert 1&2. Setting the Insert Mix level from zero to 50% might work. I have not tried this. Try it and report back.
Dual Mode is made for this because the H90 behaves like two independent stereo effects processors that have nothing to do with each other. You’re free to use one algorithm per side or both algorithms on one side in series or parallel configurations per Program.
January 26, 2023 at 6:08 pm #168689
Thanks so much for the clarification. I’m sure the main problem is that I’m a keyboard player and this is my first outboard effects unit or pedal that I’ve ever owned, so some of the terminology isn’t familiar. I was confusing “insert” with “input”.
I will try experimenting as you suggest and get back to you. But I can probably just use my DAW for the routing with the unit in Dual Mode.
This makes me think there could definitely be a market for Eventide to make an audio interface with built-in Eventide DSP effects that comes with licenses for the same plugins to also be used in the DAW. In my dream world Eventide buys Metric Halo and combines forces 😀
