Controlling h90 looper with SoftStep
Home Forums Products Stompboxes Controlling h90 looper with SoftStep
    • #193540
      danperfect
        Hi, I’m sure this should be easy (no problems getting it to work with my Morningstar), but for the life of me I cant work out what I should be doing to get the right format CC message sent to the h90 to control the looper functions. All correctly set up in the H90, but the SoftStep works, but strangely.. Here is a screen shot of my soft step parameters – any help would be gratefully received! It is sending messages using the midi expander, and they do arrive, work once, then stop.. Thanks, Dan
      • #193543
          Sorry to hear you are having issues. I’m unfamiliar with the SoftStep programming, but you’ll need it to send a High CC value when the switch is pressed, followed by a Low CC value when the switch is released.
          Can you try mapping your CC to another action like Momentary active and let me know if that works correctly?
        • #193555
            You might want to try just a single modline (one each for REC, PLAY, STOP).
            Foot On as the Source, Linear as the Data Modifier Table.
