Cosmic Web maximum length/delay time
Home Forums Products Stompboxes Cosmic Web maximum length/delay time
    • #194038
      Wardy66
        Is the maximum length of grains 12,000ms?
        If I put a very slow tap tempo via midi in then switch from tempo to ms, then it can show some very big numbers (eg 72,000ms) but seems to default back to 12,000ms in reality.
        In a non-granular way we now have effectively a 12 second delay pedal if pitch is at unity and grains are forward. I like !
        Especially as i can have 2 (or even 4) very slightly different long delays at once.
      • #194040
          Correct, 12 seconds / 12000 ms is the max delay time. With some extreme circumstances the pedal will display values beyond this as you have found, but the max delay time is fixed to 12 seconds.
          And yes, Cosmic Web is a very versatile multi-effect! If you try the Repeat A/B perform parameters you can use it as a dual looper. An example of that can be seen here: https://youtu.be/0jEvzZPuzbU?si=PYWOh9jiX9MHHIdj&t=106
        • #194041
          Wardy66
            Fabulous, the gift that keeps on giving!
