Custom exp pedal for TF
Home Forums Products Stompboxes Custom exp pedal for TF
    • #112004
      kdm1218
        Would a custom built exp pedal need to be TRS or TS? Not sure if I'm missing that in the manual or what. Looking at these: http://saturnworkspedals.com/shop/utilities/expression-pedal
      • #126841
          It should be TS, or TRS with the R unconnected.
          If you use a TRS with the R connected you get a weird situation where the value is low at each end and highest in the middle.
