DAW/H90 Integration
Home › Forums › Products › Stompboxes › DAW/H90 Integration
    • #169044
      astralpen
        I’m confused about how to cable this. DAW/patchbay outputs are balanced TRS, but the H90 expects line level TS. What cable do I use? Or do I need to use a reamp and drop back down to instrument level? Would really prefer to stay at line level.
      • #169046
          Usually, unbalanced to balanced simply unbalances that line.  But you really need to look into exactly what this “DAW/patchbay” is outputting.
          ‘Line levels’ are not created equally.  Might end up with distortion (or much worse).  Might be just fine with a short cable run.  It is difficult to diagnose remotely, without knowing the components & specs.
          You’ve got to put in the research on this one.  I may gamble with my own equipment, but I wouldn’t recommend anything specific with someone else’s gear at play.
