Home › Forums › Products › Stompboxes › Delay before H90
- This topic has 3 replies, 2 voices, and was last updated 1 year ago by
Blackstrat83.
February 27, 2025 at 1:29 pm #188471
Hello everyone!
I was trying to place my mxr carbon copy before my h90. I use it as an almost always on pedal for slapback but wasn’t working quite well. The sound was very subtle and parameters wasn’t working when moving knobs. I tought the pedal was broken so i took it of the board to try it alone and with other board as last pedal and worked fine.
Any consideration I should be aware of before keep on troubleshooting?
Thanks in advance!
February 27, 2025 at 1:38 pm #188472
Hi Blackstrat83,
A few things to try. If you put the MXR before your H90 and you bypass the H90, does it sound like normal?
Are your H90 I/O operating levels set to the default of instrument level, or have they been changed to line level for any reason?The sound was very subtle and parameters wasn’t working when moving knobs.
Here, are you referring to the H90 parameters or the MXR controls? Keep in mind if you have a delay/slap back effect going into the H90, your feeding the H90 a processed signal. This means both Eventide presets will process your dry plus whatever amount of delay you got going on at the same time.
Suggestion: place the MXR on the insert loop of the H90 using I/O 3. On the H90 in the Routing menu, create Insert 1 and put it first in your effects chain. Connect your guitar directly to the H90, not the MXR. Now you would be feeding a complete dry signal to the H90 and you would have the option of moving the insert (MXR) anywhere in the chain – before both Eventide effects, in between, or after. Typically, any time-based effects like delay works better later in the chain.
Here’s a video explaining how to use inserts: https://youtu.be/5y14LwN9oAk?t=1889&si=V8APCVYP7fQo4bos
February 27, 2025 at 1:53 pm #188473
Cool! Will try it out and come back!
Thanks a lot!
March 5, 2025 at 11:06 pm #188758
Tried everything you said and also tried the pedal after the h90. The later worked after all, the insert thing made no difference but also the h90 sounds better after all without the delay pedal in the way. Had to try!!
thanks for the suggestions
