Did you guys ever fix the FS3, BK+, BK- Midi problem?
Home › Forums › Products › Stompboxes › Did you guys ever fix the FS3, BK+, BK- Midi problem?
Viewing 0 reply threads
    • #108936
                 I reported it a while back, but the FS3, Bk+ and Bk- cc's don't work properly when using midi (my FCB1010). It should be the case that in Play mode FS1,2,3 function as Patch 1, Patch 2 and bank up. In bank mode FS1,2,3 should function as active/bypass, repeat and tap. Bank+ and Bank- should do what they say.
      In reality the following midi CC's don't work when in play mode: FS3, Bank up, and Bank down. This basically means that I can't scroll through the timefactor presets using MIDI alone, I need to have the pedal in bank mode and stomp it.
      Could this be fixed?
