Disable fine tuning in Space
Home Forums Products Stompboxes Disable fine tuning in Space
    • #157175
      bohan
        dmartinho wrote:
        Usually I change the presets with the Encoder/Preset knob, but if I made a parameter change and want to change the preset I have to way a little otherwise the encoder will fine tune the last parameter I've changed. Is there a way to disable this fine tuning with Encoder knob?
        You can press the middle & right footwitches to change presets, or hit them first and then turn the encoder for fast scrolling.
      • #116354
        dmartinho
          Usually I change the presets with the Encoder/Preset knob, but if I made a parameter change and want to change the preset I have to way a little otherwise the encoder will fine tune the last parameter I’ve changed. Is there a way to disable this fine tuning with Encoder knob?
          Thanks,
          Daniel
