Effect’s tail is still being cut off when changing presets …
Home › Forums › Products › Stompboxes › Effect’s tail is still being cut off when changing presets …
    • #111646
      I use the H9 in a parallel loop (Suhr MiniMix II) with dry kill on and wanted to see if there was a way to  control wether an effects "tail" would be cut off when changing presets, so I looked at this parameter:
      [BYPTYP] – Choose Bypass Type (DSP, RELAY, DSP+FX)
      And chose "DSP+FX", however, the effect's tail is still being cut off when changing presets …
      Does this feature exist on H9?
    • #125996
      wedelich
        We call this feature "Spillover" and it does not exist in H9.  DSP+FX bypass preserves the tails when you bypass the pedal.
      • #153184
        Mr.Echo
          Did the problem off the spillover have been solved??
          I still can’t use the spillover at the preset chance…
          Any news about it??
          Thank you
        • #153187
          bohan
            Mr.Echo wrote:
            Did the problem off the spillover have been solved?? I still can't use the spillover at the preset chance… Any news about it?? Thank you
            H9 has DSP+FX bypass feature, but it doesn't have a spillover feature that you can hear a tail when changing presets. Its hardware just cannot do that.
