Home › Forums › Products › Stompboxes › Encoder knob’s ability to change any parameter Timeout
May 25, 2010 at 12:31 pm #107100
Hi there,
I would just like to make a suggestion to change the timeout of the encoder knob (2 seconds) of its ability to change any parameter to just 1.5 seconds or a bit less. 2 seconds is kind of a bit long time already.
Reason is whenever I move any knob and decided to change to any effect it wouldn't let me unless I wait for more than 2 seconds which is in real time takes awhile.
Anyone agrees with this? 1.5 or 1.3sec or something is ok, I guess. (but not 1sec as it is too quick if you wish to use the encoder to fine tune any knob)
May 26, 2010 at 1:25 pm #120449
The current 2 second gap doesn't bother me, due to the fact that if you ever needed to change between effects, you should have them stored in banks anyway. JMO…
July 14, 2019 at 8:05 pm #152326
100% agree. This is the biggest irritation I have with this pedal. I’d turn the feature off entirely if I could.
Also I wish the encoder scrolled through presets in bank mode.sic wrote:Hi there,
July 22, 2019 at 8:25 am #152368
Well i’d like to have access to that knob timeout parameter in an expert setting menu… so everyone can change it to its liking 😉
