Ernie Ball 25k with Single Button Aux Switch – Can’t calibrate to 1-100
Home Forums Products Stompboxes Ernie Ball 25k with Single Button Aux Switch – Can’t calibrate to 1-100
    • #114812
      I am using a EB 25k with a single button aux switch using a Y splitter cable. All of a sudden my EB will only calibrate to 1-82.
      I usually run the Auto-Calibrate feature off.
      This is also happening with just the EB plugged into the H9.
      Any suggestions getting my Exp pedal back to 1-100?
    • #149608
      bohan
        bodhijames wrote:
        I am using an EB 25k with a single button aux switch using a Y splitter cable. All of a sudden my EB will only calibrate to 1-82.
        You should calibrate your expression pedal on the H9 or in H9 Control.
        If you use H9 Control, go to Pedal Settings -> General Settings -> Pedal Calibration Disabled, and then set it to OFF once to calibrate the pedal. Full heel, then full toe … maybe a couple of times, to be certain. Once the correct expression pedal range is locked in, set it back to ON.
