Ernie Ball Expression Pedal Issues (Pitchfactor)
Home Forums Products Stompboxes Ernie Ball Expression Pedal Issues (Pitchfactor)
    • #109669
      Hi All,
      I just started using an Ernie Ball 25K volume pedal as an expression pedal and it works with any preset that has been setup up already. But I am unable to do any new programming or remove any existing exp pedal settings. I've watched the Eventide video and noticed that when using the exp pedal, I am not seeing the corresponding effect module light flash, as in the video.
      I'm running the latest version 3.5.0 [4]
      Is there a setting I might be missing?
      Thanks,
      BJ
    • #124372
      I discovered that I had the Pedal Lock on. Switched to off and now able to program exp pedal.
    • #124373
        The only thing that I can think of is system settings -> UTILITY -> PDLOCK is set to ON (and it should be OFF to program expression pedal assignments).
