Eventide Blackhole
Home Forums Products Stompboxes Eventide Blackhole
    • #116355
      So i just ordered a blackhole and already have a question.
      Is it possible to route two mono synths trough it? I think it’s possible with the two bigger sisters.
      Thank you 🙂
    • #157191
      joecozzi
        If what you’re trying to do is process each synth individually, at the same time, then the answer is no. There is no Eventide pedal that will allow you to do this. Blackhole, or any Eventide pedals for that matter, have stereo inputs, but they don’t function as dual mono signal chains, except in extreme cases with one or two algorithms.
        It is recommended that if you wish to process two mono synths at the same time with one Blackhole pedal that you use an external mixer, routing both synths to it, and connecting Blackhole to one of the mixer’s FX sends.
      • #159689
        pytheus
          Blackhole tone question:
          Hi all,
          Thank you in advance!
          Does anyone know if the Blackhole can this sound Trey is getting from the Space?
          start 21:25
