Eventide Device Manager – Tricerachorus workflow simplification
Home Forums Products Stompboxes Eventide Device Manager – Tricerachorus workflow simplification
    • #192220
      RadekPilich
        Hello Eventide. Could you please improve the workflow for controlling the pedal from the app a bit?
        Particularly, I would like to see the following:
        1. Option to disable the “protected” mode. Currently it’s not possible to switch presets with a single click if the current preset has been modified. I would like to be able modify the preset without saving it and easily switch to another preset with a single click, without having to click cancel the modifications.
        2. Add horizontal or vertical slider for expression control.
        3, Change the switches at the top (page, state, swirl) to works as toggle buttons rather then / in addition to roll out menus. Just a single click to toggle between states.
      • #192226
          You may now use the H90 Control app instead of Eventide Device Manager with your TriceraChorus.
          This doesn’t address all of your requests but its a big improvement and I think you’ll find it is a better experience.
          https://www.eventideaudio.com/downloads/?product=H90+Control
        • #192266
          RadekPilich
            Thanks, I forgot to change the one that’s pinned to the taskbar and kept using the old one 😆
            So the new one solves the first issue, great.
            The old one looks better in my opinion and has better control of expression. The new one adds the roll out menus for expression as well 🤦‍♂️
