Eventide H9 as MIDI Controller
Home › Forums › Products › Stompboxes › Eventide H9 as MIDI Controller
    • #113062
      jessetal
        Is anyone here using an H9 f/x pedal to send MIDI CC’s from its MIDI out port to another hardware device?
        I’ve set up the 10 parameter knobs in the H9 Control app app to transmit CC’s starting with MIDI CC 22 for Knob 1. I can see the values change on the H9 pedal when I move knobs in the app. However, nothing is happening in my target MIDI device (my Octatrack), which has its MIDI in attached to my H9’s MIDI out.
        I’m able to adjust Octatrack settings from my iPad using the MIDI Designer Pro app but I can’t get things going from the H9.
        Any suggestions?
      • #141672
          Make sure that the MIDI channel numbers are the same. Set up the destination unit for MIDI Omni if uncertain.
