EXP controls output volume bug?
Home › Forums › Products › Stompboxes › EXP controls output volume bug?
    • #112684
      JCR
        Does the new option to control input/output volume by expression pedal with midi contain a bug? Whenever I set a preset to control the output volume the lightring around the big knob is lit when the expression pedal is moved indicating the volume. Great so far, but the lightring stays lit all the time, even after selecting a presets without the volume control enabled. The only way to get the lightring off is to power the H9 off and on. It is more logical to lit the lightring only if the selected preset has the option enabled to control the volume by expression pedal.
      • #139715
          The lightring usually shows the latest change, whether volume or parameter. It sounds like it should go off when a preset is loaded if it has been set by the volume pedal. I'll add it to the list.
