Exp Pedal and Morley A/B/C
Home › Forums › Products › Stompboxes › Exp Pedal and Morley A/B/C
    • #108776
      jmusolino
        Hi all…I use TF, MF, and PF, and an EB Jr 25 volume pedal as an exp pedal. I know there's a peocedure for using the MIDI connectors to allow the EB to control all 3 Factors, but I'm wondering if anyone's used an A/B or A/B/C pedal (e.g., the Morley) to assign the exp pedal to one or more Factors at a time. Thanks…Joe
      • #123467
        achaput
          I have not tried this but would be curious to know if it works! We have successfully used "y" cables to connect a single expression pedal to more than one Factor Pedal.
        • #123469
          jmusolino
            I got hold of a Morley a/b/y and ran my PF into the A side with the EB Jr in the input to see if it would get a signal. Unfortunately, it didn't, but I'll try some different cable combinations and see how that works. The idea here is to be able to choose at any time the Factor pedal or pedals that use the exp pedal. So if I'm using the PF to change a harmony from a 3rd to both a 3rd and 5th to a 5th and I'm using the MF and TF as well, I'd use the a/b/c to choose only the PF with the exp pedal. Or maybe the PF and TF. It seems that the midi cable connection with a single exp pedal would cause it to change parameters on all 3 pedals. Thanks…Joe
