expression pedal problem with H9
Home Forums Products Stompboxes expression pedal problem with H9
    • #170385
      bendod
        Hi, I have a new H9 max that I’m trying to control with my boss ev-30 expression pedal.
        the problem is every time I use the expression pedal the overall volume is also effected, is there a way to separate them?
        I tried turning off the ISW and OSW on the global menu but got no results.
      • #170400
        joecozzi
          Does this happen with all presets are just a specific one? What other parameters are mapped to the expression pedal? H9 Control will give you the quickest idea what is mapped and display the range of control.
        • #170427
          bendod
            Thanks for the reply
            I changed to a different trs cable and now it works good.
