Factor Lib does not transfering the expression pedal settings in pitchfactor
Home › Forums › Products › Stompboxes › Factor Lib does not transfering the expression pedal settings in pitchfactor
Viewing 0 reply threads
    • #108441
      To this date I'm loving the Pitchfactor and had no issues whatsoever Smile. Recently I decided to organize the PF presets using Fac Lib 1.8. So I dragged and drop the presets in order and copied it to the pedal; suddenly the pedal started to crash.
      Firstly it restarts occasionally. The preset values also have changed in some programs. I guess this can be solved by restoring to the factory setup Huh? Also It appears that when you organize the presets, the expression pedal settings are not transferred. Is this something that has been addressed before?
