Factor Pedals: Using Midi to select presets in a bypassed state, and the Aux switch for effect On/Bypass?
Home Forums Products Stompboxes Factor Pedals: Using Midi to select presets in a bypassed state, and the Aux switch for effect On/Bypass?
    • #109254
      luca9583
        I've got a Pitchfactor and a Voodoo Lab Control Switcher, all controlled by an MFC 101 foot controller.
        I want to be able to use the Control Switcher to turn PF On or Off (Bypassed) via the Aux Switch input, and then use Midi to call up my PF presets but in a bypassed state. I find that switching the PF On or Off this way is faster than by Midi.
        At the moment the Aux switch works fine but whenever i select a preset via Midi it always comes on with the effect active, regardless of the position of the Aux switch. Is there a way to remedy this or does Midi selection of presets always override the Aux switch's position?
      • #123967
          On the latest software, if you save a preset when bypassed, it will come up bypassed if you load it from MIDI.
