Factor Pedals with Godlyke Powerall
Home Forums Products Stompboxes Factor Pedals with Godlyke Powerall
    • #108701
      I've spent hours researching and haven't found a solid answer to this question.  Can you power 2 factor pedals with the Godlyke powerall?  Godlyke's website says the ground hound is recommended which makes things kind of confusing.  I know Eventide sells there own power supplies but there a bit too big for me.
    • #123399
        I fear you'll not get an answer until someone tries it. I have not, so I know nothing, but here are some things to consider:
        1) It would appear to be a switcher, so there is a risk of increased noise level (background hiss).  They say it has 2A output, so it should have enough current to power a few 'Factors.
        2) If you try to power more than one pedal from a single supply, there is a danger of ground loops. Presumably this is why they recommend their ground loop filter. Again, don't  know how well it works.
        Note that damage caused by  using a non-Eventide supply is not covered under warranty.
