Factor Series Midi Control
Home Forums Products Stompboxes Factor Series Midi Control
    • #113456
      I understand how to connect and make the presets change via midi on both pedals but my question is:
      Is there a way to have the timefactor on say preset 1:1 and the mod factor off?
    • #143393
        I assume by "off" you mean bypassed. In this case, you could set up the MIDI Maps on each pedal so that a chosen MIDI Program Change would select (say) 1:1 on one pedal and bypass on the other. See UM for more information (MIDI – RCV MAP – look at the online one rather than the printed version).
