Feature Request – H90 Insert always active globally
Home Forums Products Stompboxes Feature Request – H90 Insert always active globally
    • #190817
      mikedeluccia
        I like having my entire pedalboard connected as an insert on my H90, this way I can either put it before, in between or after my 2 H90 alorithms. This feature works amazing, I can do my pitch shifting into my pedalboard for some dirt and then into my h90 reverb, or I can have the whole pedalboard before a reverb/delay patch, etc…  Its a really simple elgant solution and I love all of the insert points in the H90.  However, when I bypass the H90 effects using the P bypass, it now bypasses my entire pedalboard.  The work around is to either swith to a ‘blank’ H90 patch with the thru and insert connected, or to manually bypass each algo a and b.  It would be an amazing glabal feature to have a menu option for inserts always active, so I can bypass the H90 and keep my pedalboard active. Hope this makes sense to other users and can be implemented in an update!
      • #190819
        mikedeluccia
          I just saw this was implemented in P bypass mode, AB only
