Home › Forums › Products › Stompboxes › Finding H90 presets
- This topic has 6 replies, 4 voices, and was last updated 5 months, 2 weeks ago by
Eventide Staff.
October 7, 2025 at 1:41 pm #192489
I overwrote a factory preset I didn’t think I needed, and now I’d like to get it back. It was a synth-sounding preset with escalating modulation or oscillation it reminded me of the Lucas Film THX sound effect. I can’t do a full factory reset because I have many custom sounds saved on my H90. If anyone knows which setting I’m talking about and can send me a screenshot so I could rebuild it, I’d really appreciate it — or if you know of a video where someone goes through all the presets, that would help me identify it.
October 7, 2025 at 9:31 pm #192505
You should be able to import the factory presets into a new list (or copy your current presets to a new list before importing), then find the original preset you are looking for that way.
October 8, 2025 at 12:15 am #192506
That is the problem I can not find or remember the name of the preset.
October 8, 2025 at 8:59 am #192507
That’s a tall order for most humans. But in this case, A.I. is your friend:
October 8, 2025 at 10:21 am #192511
Thank you, Brock, Dynamic Swells is the setting I was looking for. If I could find the settings for the patch, I will be all set.
October 8, 2025 at 10:33 am #192512
Factory Programs can’t be edited, just the copies of them in User List 1 can be modified.
It has to be in in the Factory List.
October 8, 2025 at 1:33 pm #192514
If you can clarify whether you’re looking for a PolySynth Preset, or a Program that uses PolySynth, that would improve your search.
As Brock mentioned, the Factory Programs/Presets cannot be edited or erased.
Using H90 Control is the best way to find a certain Program/Preset:
- If searching for a Program, use the Program library and select the PolySynth filter: https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/h90-control/program-library.html
- If searching for a Preset, use the Preset library and select the PolySynth filter: https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/h90-control/edit.html#preset-library
Sounds like you may be searching for the “Dramatic Swell” Program.
