Firmware Update Error
Home Forums Products Stompboxes Firmware Update Error
Viewing 28 reply threads
    • #193992
      rtpilk
        I’m getting the following error when trying to download the latest update.  Your assistance is appreciated.  Thank you.
        Download of ‘h90-1.12.5.pak’ failed with status: 404
        OK
      • #193994
        eruption77
          I’m getting that same error trying to download/install the update.
          When I initially clicked Download it appeared to download in just a second or two.  Now I no longer have the option to Download, only Install, and when clicking install I also get that same error.
          Running 1.9.13 of H90 Control and firmware 1.11.4.24.
        • #193995
          eruption77
            To add, I checked the below path:
            AppData\Roaming\Eventide\H90 Control\Firmware
            The .pak file (h90-1.12.5.pak) is only 1kb in size.  This might be an issue on Eventide’s end.
          • #193998
            mattam
              Same here. On Mac OS X. H90 Control fails to download the .pak. Disappointing as I’ve just taken my H90 out of the box and wanted to get it up to spec before trying it out. Guess I’ll have to wait for the new algorithms to actually be available.
            • #193999
              emgbeeker
                Update is still broken. 404 error when I attempt to install the latest firmware. I wish we didn’t have to deal with firmware servers…just one more link in an increasingly fragile chain of online service “middlemen”.
              • #194000
                mattam
                  Same issue on my Windows PC also.
                  The attached screenshot is from the Mac. Same message on the Windows PC.
                • #194002
                  bilyum
                    Same 404 (Not Found) for the .pak file issue for me on both Windows and Mac. Also noted the file size is next to nothing, so it hasn’t downloaded. The .os file appears to download just fine.
                  • #194006
                    amc8
                      also getting this – tried to do the manual update via recovery mode and have effectively now bricked the machine with “factory content not found” displaying on the h90….
                    • #194008
                      DannyJoe
                        Same issue……
                      • #194009
                        shuuniyoruto
                          Here to +1 to the same issue happening to me on both Windows and Mac. My brand new H90 is on 1.7.5, so it’s quite a bit behind.
                        • #194012
                          ghostntime
                            Same issue on Mac OS Ventura and Mac OS Sequoia
                          • #194013
                            auditorymanipulator
                              Same issue on M1 Macbook Pro running Tahoe and also tried via 2017 iMac running High Sierra. Have tried workarounds, including factory reset + recovery mode.
                            • #194016
                              mattam
                                A 404 error means the file doesn’t exist on their web server at the location it attempted to download from. They either need to put the missing file there or give it the correct name/path. A problem Eventide needs to fix on their end.
                              • #194017
                                mattpreacherz
                                  Same Here.
                                  Since I got the H90, I’ve never been able to successfully perform an update on macOS. I don’t find that very professional.
                                • #194020
                                  karhunensami
                                    Same issue here, on macOS
                                  • #194021
                                    amc8
                                      Yep really need to get this fixed asap – h90 is totally non functional now for me
                                    • #194022
                                      mattpreacherz
                                        M%aybe one day, i will make an Update with my Mac.
                                      • #194023
                                        Gerrit Valckenaers
                                          Same 404-issue on Mac here
                                        • #194025
                                          daanbaas
                                            Same issue on Win 11 over here.
                                          • #194026
                                              Hi all,
                                              Sorry for the update issues. We found there was an issue with the server to download the update files and we’ve just fixed that.
                                              Please follow the instructions for a Recovery Mode update and that should do it: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/appendix/startup.html#recovery-mode
                                            • #194028
                                              ghostntime
                                                Beautiful, the update works! Thank you, Eventide staff, for the quick recovery.
                                              • #194030
                                                rtpilk
                                                  DITTO, Up And Running.  Thank you!!
                                                • #194031
                                                  DomenicoDiano
                                                    It works! Well done Eventide for the quick resolution. Now let’s go full Granular.
                                                  • #194032
                                                    DomenicoDiano
                                                    • #194483
                                                      Joy Pop
                                                        when downloading the update to the newly purchased eventide h90, the h90-1-12.5.os eventide file is not downloaded what should I do? The methods mentioned above do not work. Is it possible to simply download these files from somewhere and transfer them through a computer without using the app? Please help!
                                                        • #194485
                                                            To confirm, have you tried Recovery Mode? https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/appendix/startup.html#recovery-mode
                                                            Are you seeing an error message?
                                                            If you’ve already tried this, please email support@eventideaudio.com and we can troubleshoot the issue further there.
                                                        • #194486
                                                          Joy Pop
                                                            Yes, I used the recovery feature, as well as factory reset, but it didn’t help.
                                                          • #194487
                                                            Joy Pop
                                                            • #194492
                                                              Joy Pop
        Download of ‘h90-1.12.5.os’ failed with status: 200 What’s the problem?
                                                              • #194494
        Have you emailed support@eventideaudio.com? We can provide further instructions there.
