Freeze with Shimmer Algo
Home › Forums › Products › Stompboxes › Freeze with Shimmer Algo
Viewing 0 reply threads
    • #109159
      rabiddiabetic13
        When I use pitch freeze the pitched shifted sounds fade away, basically cuts right out when I use hot-switch to activate.  Is this the way it should work, I was under the impression I would hear the two shifted pitches in a hold pattern and could play over it with reverb.
        Thanks,
        Anthony
