Home › Forums › Products › Stompboxes › future H9 support
- This topic has 3 replies, 3 voices, and was last updated 3 years, 3 months ago by
coirbidh_99.
November 11, 2022 at 1:38 pm #166575
Hi, now that we have a follow product that doesn’t use an app-store, a question arises:
context: I have five H9’s. My first graduated Max Class when the Max program started by virtue of buying 1/2 the algorithms; the remaining four are Cores elevated to Max since I own one Max.
Q: where is the accounting for Max/Cores done? does the app check back with you with my account info? is the info stored in H9 Control data that will go away if I replace the iPad? if Eventide goes out of business, loses the customer data, or decides we’ve had enough – heaven forbid! – do my Cores revert to Core’s again forever?
thank you for all the cool products over the years! still have my H3000, GTR4000 and H8000FW/Evenet
November 11, 2022 at 4:25 pm #166585
I have five H9’s. My first graduated Max Class when the Max program started by virtue of buying 1/2 the algorithms; the remaining four are Cores elevated to Max since I own one Max. Q: where is the accounting for Max/Cores done? does the app check back with you with my account info?
When you open the app, if you are logged in, nothing happens. Once you log in the app cross checks the credentials with Eventide’s server to make sure you’re a registered user and the serial numbers correspond to your account. If it checks out, you can use the app.
Is the info stored in H9 Control data that will go away if I replace the iPad?
If you’re referring to user preset lists, yes. This type of data lives on the device. That’s why I always email my preset lists to myself in case I need to put them on another device.
No, unless you deregister them before we hypothetically go out of business. Otherwise, they will be Max units FOREVER.
Thank you for all the cool products over the years! still have my H3000, GTR4000 and H8000FW/Evenet
You’re welcome!
November 12, 2022 at 9:02 am #166603
thanks again Joe! you’re the best!
November 12, 2022 at 10:42 am #166604
Unless you’re regularly backing up your iPad, either to iCloud or to a local computer running iTunes, in which case you *should* be able to install that image on a new device and have everything ready to go.
