- This topic has 5 replies, 2 voices, and was last updated 1 year ago by
Eventide Staff.
March 31, 2025 at 3:23 pm #189327
Where should I be able to find the H3000 Factory Mk II installed on MacOS Sequoia? After downloading and running H3000-Factory-Mk-II-1.2.0-osx-installer.dmg, which does not seem to provide any options to select installation location, I don’t see VST3 or AU files in the usual system locations, and Ableton scan does not find anything. iLok has activated H3000 Factory but I need some help actually getting these plugins installed, unlike my other Eventide plugins which are fine.
FWIW my other Eventide plugins were installed by default in /Library/Audio/Plug-Ins/VST3/Eventide/
March 31, 2025 at 4:54 pm #189331
It should be installed in the folder: /Library/Audio/Plug-Ins/VST3/Eventide/
Have you tried running the installer again?
April 1, 2025 at 5:42 am #189336
Yes, several times. No errors show up during attempted installs, but nothing is added to that folder.
Is there any way to install from the command line, or directly from unpacking a download? Or to debug what is going on? I have many plugins running on that dedicated audio computer without issue.
April 1, 2025 at 12:54 pm #189343
Sorry to hear you are still having issues.
Can try a full uninstall of the plugin (/Applications/Eventide/Uninstallers) and then run the installer again? Does that resolve the issue?
April 1, 2025 at 3:08 pm #189344
That worked. Thought I had tried that before but perhaps not. Thanks!
April 1, 2025 at 3:14 pm #189345
Good to hear! Thanks for reporting back.
