H9, account and update
Home Forums Products Stompboxes H9, account and update
    • #115739
      nicocaumon
        Hi !
        I’m about to buy to someone an H9 Corr that has been MaxedOut.
        I’ve seen on this forum that if a H9 has been maxed out, it will stay this, even if we tranfer my account on the pedal.
        But, ir one day the pedal has a bug or needs an update, and it resets the pedal memory : will I be able to have it MaxOut again without purchasing the algoythms again ?
        Thanks
      • #153955
        bohan
          nicocaumon wrote:
          Hi ! I’m about to buy to someone an H9 Corr that has been MaxedOut. I’ve seen on this forum that if a H9 has been maxed out, it will stay this, even if we tranfer my account on the pedal. But, ir one day the pedal has a bug or needs an update, and it resets the pedal memory : will I be able to have it MaxOut again without purchasing the algoythms again ? Thanks
          Once an H9 is maxed out, it will always be a Max, no matter what you do to it.
        • #153959
          nicocaumon
            I just had an answer from the support : once the owner is logged out, you loose access to the presets :(((
