H9 and Logic Pro X ?
Home › Forums › Products › Stompboxes › H9 and Logic Pro X ?
Viewing 5 reply threads
    • #112290
      Hi Folks 🙂
      Is it possibel to use my H9 Max for recording on my MacBook Pro (OS Yosemite) in Logic Pro X,what for equipment i need and how ?
      Thanx for answer with greetz from good old germany 🙂
    • #127433
      badmelonfarmer
        Do you mean can you use the H9 as an Audio Interface into your Mac?
        No, you can't do that … the USB does not pass audio data.
        You would need a separate audio interface.
        You can use the H9 in front of the audio interface if you wish and use the Amp Designer in Logic
      • #127436
        Thanks for the help and Info Badlemonfarmer 🙂 i have audiointerfaces (Axe FX II XL,Apogee One and Jam), and try it to play the H9 effects into Logic X 🙂
      • #138123
        badmelonfarmer
          No Problem
          BTW … the H9 works really nicely in the FXLoop of the Axe-FX II as this is what I use as my main Audio Interface
        • #138124
          Wowwwww…great info!!!! thank you very much Badmelonfarmer 🙂
        • #138125
          badmelonfarmer
            No Problem.
            It sounds best in stereo
