H9 aux not working
Home › Forums › Products › Stompboxes › H9 aux not working
Viewing 0 reply threads
    • #114077
      Lenny M
        hey guys: need a bit of advice. I’m using exp pedal (Hotone Soul Press) and a Boss FS5U > exp input on the H9, using an insert cable (stereo > 2 x  mono) . The exp pedal works backwards (when fully down. vertically, it send a value of 0 and when fully up “off” it sends max value). Also the FS5U doesn’t work at all when set to ‘increment and load preset’. The weird thing is that when I swap the cables, the exp pedal DOES increment and load presets. I’m doing something wrong but I just can’t see it. Many thanks in advance for any tips you many have.
