H9 Bypass question DPC5
Home Forums Products Stompboxes H9 Bypass question DPC5
    • #112818
      Hi everyone
      When I hold down a preset button to bypass the loop on my DPC5 which has an H9 patch and a whammy patch on, it only mutes the whammy and the H9 moves to a different preset which I can hear. It goes to the same h9 preset when I hold down any of the preset buttons on the dpc5 to bypass the loop so it must be saved as a bypass patch on the H9??? Any idea where I am going wrong?
      Many thanks for any help
      Sent from Yahoo Mail for iPhone
    • #140414
      chris.veitch
        Do you know which PC number the DPC5 sends when you bypass? I use a DPC8 which sends PC0.
        I you haven’t already, you will need to tell the H9 to go into bypass when it receives the appropriate PC number.
        In H9 Control go to Pedal > MIDI Settings > Program Change Receive Map and set Program Change Number 0 (for example) to bypass the pedal. It sounds like your H9 might currently be set to load a particular preset number (I think the default is to load Preset 1).
        Hope that helps.
