H9 clipping
Home Forums Products Stompboxes H9 clipping
    • #111452
      I'm having problems with clipping. I've been demoing the octaver algo. I
      like it in front of the amp, but when it's in the loop the pedal clips
      and distorts. I've tried lowering the send volume on the amp(Mark V) and bumping
      up the gain in the line in menu within the pedal. What am I
      doing wrong? I've had no problems with any of the algos before. Are the
      Pitchfactor algo's so much louder than the other algos?
    • #125539
        Make sure the input and output levels are set appropriately (see "Setting Levels" in UM).
        Some loops seem to have excessively high signal levels designed for line level rack effects rather than stomp boxes.
      • #125540
        gkellum
          hendrik7:
          What am I
          I don't think you want to turn up the gain in the line in menu within the pedal.  You probably should turn that back down to where it's not clipping and turn up the master volume on your amp so you're at the same level as you were before.
          PitchFactor's algorithms are not necessarily louder than other algorithms, but different algorithms have different gain structures.  And if you go into Octaver for example with a signal that already has a lot of bass, that's going to clip sooner than sending the same signal into a reverb.
