H9 Control Note Values to Time Question
Home › Forums › Products › Stompboxes › H9 Control Note Values to Time Question
    • #115656
      koo
        Still new to H9 Control and I’m confused by its conversion between note values in tempo mode and ms when tempo is off, using the Vintage Delay algorithm as an example.
        If I enter 100bpm and pull the delay knobs to 1/4, I can get values ranging from about 250ms to 300ms. I assume I’m getting varying values because the knob doesn’t snap to exactly a quarter note, right? But why am I not getting around 600ms for a quarter note delay at 100bpm?
        When I take it from the other direction and set a delay of 600ms, then turn tempo on at 100bpm, it labels the delay as 7/16.
        I am guessing there’s user error at work here – can someone kindly explain where I’m going wrong?
      • #153475
        camn
          I don’t know if this is real… But I have never thought that those numbers correlated.
          Like, I conceptualise a Tempo mode, and a non tempo mode. And the knob is just set to a clock position.
          So 1oclock is whatever dotted 1/4…or it is whatever XXms. They cannot be related, because the 1oclock position should be consistently XXms despite the global tempo.. And consistently dotted 1/4 despite global tempo.
          Caviat* I have not tested this theory.
        • #153499
          skywriter
            BPM is relative to reference clock provided by internal or external clock in tempo mode; WHOLE, 1/2, 1/4, etc… of reference clock. Out of tempo mode (no reference clock), time is measured in absolute time; milliseconds.
            In pedal settings you can select MIDI source as clock source. Otherwise the internal clock is set with the tempo button legend.
          • #153477
            koo
              camn wrote:
              I don’t know if this is real… But I have never thought that those numbers correlated. Like, I conceptualise a Tempo mode, and a non tempo mode. And the knob is just set to a clock position. So 1oclock is whatever dotted 1/4…or it is whatever XXms. They cannot be related, because the 1oclock position should be consistently XXms despite the global tempo.. And consistently dotted 1/4 despite global tempo. Caviat* I have not tested this theory.
              So, said another way, there is no conversion going on between the two modes – that makes sense and would explain it, thanks!
