H9 doesn’t generate any midi signal, can’t be used as a midi clock source?
Home › Forums › Products › Stompboxes › H9 doesn’t generate any midi signal, can’t be used as a midi clock source?
    • #111579
      PacoDicenta
        Hello, I have an Eventide H9. Software updated – 4.4.6(1)
        I need to use H9 as a midiclock source, and it seems impossible.
        No matter how I configure midi settings, no signal comes out from the "midi out" port.
        Midi output mode= Transmit
        Midi cable= tested, working ok
        Other devices tested when receiving midiclock from other sources. Working ok.
        Using a Midi Monitor software, no signal comes from H9. No midi controller signal, no clock signal, no system exclusive messages. NOTHING. Software tested with other devices, working ok.
        H9's midi-in and midi-out ports working perfectly when receiving midi signal and re-transmitting it cia midi thru, so it's not a physical problem.
        Both H9's manual and Eventide's site says that you can use H9 as a midi clock source.
        So, is it true? Can I use it as a midi clock source? Indifferent
      • #125809
          You can use it as a MIDIclock source, Look at User Manual p.42 – as well as MIDI/OUTPUT=XMT you need to set MIDI/CLK.OUT to ON.
