H9, import factors presets ?
Home Forums Products Stompboxes H9, import factors presets ?
    • #111065
      matcaster
        Is there any way to import my space presets in my H9 ?
        thx
      • #124748
          Assuming you have the algorithm on the H9 it is certainly possible.
          First, load the preset on the Space.
          Then load any preset using the same algorithm on the H9.
          Then connect MIDI out on the Space to MIDI in on the H9. Make sure they are set up the same.
          Then, on the Space, go to SYSTEM MIDI//DUMP/CURRENT
          Press the encoder, and a second later the preset will appear on the H9.
          We'll try and make this easier in the future.
