Home › Forums › Products › Stompboxes › H9 input / Output
May 25, 2013 at 7:40 am #110951
Does the H9 use standard mono unbalanced jacks, and can they be switched between line and instrument / amp levels? Like the other factor pedals?
Alan
May 25, 2013 at 3:32 pm #124511
Yes to the first, no to the second.
The H9 has slightly higher dynamic range than a 'Factor, and also has an input gain control for low output instruments.
May 25, 2013 at 4:10 pm #124512
aah i see – so if i switch between instrument and line at times – i should see if im happy with the level and adjust it if needed. – i did see that function in the ios app.
June 24, 2013 at 4:34 pm #124580
Hi
Does this mean it has newer/different A/D & D/A convertors?
July 18, 2013 at 4:26 pm #124631
I was plagued by noise issues on my Timefactor due to the guitar input signal being too low versus the noise floor. Does the adjustable input level on he H9 take care of this?
My previous experience with the timefactor noise issues left me scarred (imagine a great sounding delay thats too noisy), so im keen to get the H9 if the input gain problem is solved.
can Eventide confirm please?
July 18, 2013 at 4:32 pm #135486
Yes, it should help. We added the input gain feature specifically to work better with guitars with low level outputs.
