H9 input / output mono/stereo question
Home › Forums › Products › Stompboxes › H9 input / output mono/stereo question
Viewing 3 reply threads
    • #113487
      chris.veitch
        Hoping fro some wise words here. I use my H9 in an amp fx loop and run a second amp off the output 2 to get full benefit of stereo effects. only problem is it also outputs my amp signal when H9 is bypassed which I don’t want. Is there any way to stop this?
        Also I would like if possible to keep the DSP+FX so i get the fx trail remaining whihc is really cool.
        Any help appreciated!
      • #143521
          You could try Killdry, which will mute the output when it is bypassed. Not sure what you want it to do.
        • #143528
          chris.veitch
            Hi Nick,
            I tried kill dry but it also muted output 1 so I had no guitar signal going to the amp at all.
            What I’m after is output 2 being muted so I just get my guitar tone (no effect) through output 1. Then when I use an H9 effect, output 2 kicks in so I get stereo which goes to a second amp.
            I’m trying to avoid having the second amp also broadcasting the mono (no effect) guitar tone as I’ve already got that coming out of my main amp.
          • #143538
            h9controller
              Only thing I can think of is using the WET/DRY routing option on the H9.  But you would need to setup up two presets of each effect:
              One presets would be in STEREO mode for full effects (the ACTIVE state preset).
              The second would be saved with WET/DRY 2 and a MIX level of 0 (the BYPASS state).  The dry signal would come out of ouput 1 and the wet signal (which has a MIX of 0) would ouput nothing on output 2.
              This sounds very tedious to incorporate for all presets and wouldn't work for most MODFACTOR algorithms since most don't have a mix control.
              I hope this helps!
