H9 Inserted into H90
Home Forums Products Stompboxes H9 Inserted into H90
Viewing 4 reply threads
    • #171391
      micahvid
        I am attempting to insert a H9 into an H90 in stereo. I have Insert Routing selected as well as stereo however I am getting no sound from the H9.  Has anyone done this with success?  If so, can you share your settings including send and return levels, latency and polarity?  And any other info.
        Many thanks!
      • #171392
        joecozzi
          Make sure you have the correct connections. Some people don’t realize input and outputs are on opposite sides of the H90, not stacked above each other; a common mistake.
          H90 Out 3 to Input 1 on H9
          H90 Out 4 to Input 2 on H9
          H9 Out 1 to Input 3 on H90
          H9 Out 2 to Input 4 on H90
        • #171548
          micahvid
            Thanks for response!  It is working!
          • #171549
            joecozzi
              Thanks for reporting back. Glad you got it working!
            • #171974
              zhensun
                Do you use H9 inserts in parallel? If so, could you please share your latency and polarity settings with me?
