H9 Looper Length
Home Forums Products Stompboxes H9 Looper Length
    • #112241
      I understand that the Looper algorithm is written to support the TimeFactor hardware, and thus the looper length is limited to 12 seconds at full quality.
      Technically, does the H9 have the capacity to allow longer looping times at full quality? And if so, is this planned for a future release?
    • #127339
        Sorry, no. It is limited by the amount of installed sram memory, which in this case is the same as the TF.
      • #127342
        Bodde
          What about the delay time? Can that be increased to 8 seconds or even better 16 seconds? Not sure if this is possible or if there are plan the increase the delay time in the near future? I use these really long delays for my soundscapes. I prefer delays over the looper for this although the loop can also do it (but it feels different with the looper and with delay you have other options). Would be great if the H9 could do this so I could use this as my main delay.
