H9 Max harmony question
Home Forums Products Stompboxes H9 Max harmony question
    • #113949
      Can the H9 do two and three part intelligent harmonies for guitar?
    • #145454
      Yes
      From the manual:
      Diatonic pitch shifters track the notes that you’re playing and shift the pitch by the selected
      harmonic interval based on the Key and Scale that you’ve selected.
      Diatonic Shifter features twin independently-controlled pitch changers (A & B) with independent
      delays and feedback. Diatonic tracks the notes that you’re playing and automatically adjusts the
      amount of pitch shift so that the resultant note is in-key. Use the PitchA/B control knobs to set each
      pitch interval. Use the Control Knobs to select the key, scale and interval.
      Quadravox is similar to Diatonic but delivers up to four pitch shifted voices (A, B, C, D) instead of
      two. You can select the interval of each voice independently. You can also turn OFF any of the
      H9 Algorithm Guide PitchFactor Algorithms voices.
