H9 or Core?
Home › Forums › Products › Stompboxes › H9 or Core?
    • #111468
      grimley
        As an owner of Space, Pitch Factor and Time Factor, would it make more sense for me to get a H9 Core over an H9?  Are all the missing algorithms in the Core already covered by the Factors?
        is there any physical difference between the 2?  Can all the H9 algos/presets be purchased for the Core and what would that cost?
      • #125571
        gkellum
          grimley:
          Well, the H9 Standard has two ModFactor algorithms — Chorus and TremoloPan — and UltraTap, but you already have the other algorithms in the Standard in your other Factor pedals.  You do get a coupon with the Core, and you will get coupons for your Factor pedals that you can use to buy H9 algorithms.  So, if you really wanted those three aforementioned algorithms, you do have coupons.
          grimley:
          No, there is no physical difference between the two.
          grimley:
          Yes, all of the algorithms can be purchased for either the Core or the Standard.  Purchasing works exactly the same for both.  Algorithms run at $20 each, but we have started doing monthly specials.  Rotary for example is on sale this month for $10.
        • #125572
          grimley
            Awesome thanks!
